IOS XR redundancy on one ASR and 2 interfaces
Apr 5th, 2010
What are my options for redundancy on one ASR, 2 interfaces. I know I  have options like HSRP and VRRP but I am looking for something I can do  between two interfaces on the same router.
Perhaps policy routing is my solution. I have to do some more research  on IOS XR. What do you guys think?
Giuseppe Larosa Sun, 04/11/2010 - 05:02
Hello Mark,
check if IRB integrated routing and bridging can be used in that case the L3 config will be on a BVI interface and the interfaces are associated to the bridge-group.
Hope to help
msinno123 Mon, 05/03/2010 - 21:40
Exactly. Link bundling - or Ethernet's LAG - or Cisco's EtherChannel
is supported on IOS-XR since 3.7.2+.  The options are actually quite plenti
ful and allow for either standard LACP load balancing options or newer 1:1 settings.
Please note, the 1:1 settings only allow 1 active and 1 standby, but the regular LACP option allows for up to 8 active with 32 inactive members.
The nice thing about this is that LAG is a IEEE standard and not a Cisco standard so interoperability is more likely with another service provider that uses other than Cisco.
