IPv6 and DHCP labs?
Answered Question
Apr 5th, 2010
Hello, I was wondering if anyone could point me to some examples of using IPv6 with DHCP in a campus environment?  I have looked around the Internet for lab examples on this and have only come up with syntax examples.  I plan on setting up just a small environment, probably only 1 router connected to 1 host just to experiment with dynamic IPv6 address allocation and I was wondering how to do this.  Thank you for your help!
-Dan
Correct Answer by Ganesh Hariharan about 6 years 11 months ago
-Dan
Hi Dan,
Check out the below link hope that helps
http://www.cisco.com/en/US/docs/ios/ipv6/configuration/guide/ip6-dhcp.html
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Correct Answer
Ganesh Hariharan Mon, 04/05/2010 - 23:08
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
-Dan
Hi Dan,
Ganesh.H
boogeymanperson Tue, 04/06/2010 - 06:53
That should work out just fine!  Do you know of any other resources?  I appreciate the help!
Related Content
