Bulk Subscribed Phone Services CUCM 6.x
Apr 6th, 2010
Is is possible to do bulk Subscribe/Unsunscribe  for given device pool instead of going to each phone 1 by one. I have look under BAT and couldn't find anything under updates phones field. Attach is the screen shot . Thanks
Aaron Harrison Tue, 04/06/2010 - 01:11
  • Community Spotlight Award,
    Member's Choice, May 2015
Yes, you can do this via BAT. You first need to create a phone template in BAT which has the full list of services you want to put on the phones.
Then go to Bulk Admin, Phones, Update Phones, Query... select your device pool and hit 'Find...'.
When you have the correct list of phones displayed that you want to update, click 'Next'. At the bottom of the page, there should be a section that allows you to apply the list of services from any phone template. Select the phone template, and the services will be added.
Aaron
Please rate helpful posts...
samaykhan79 Tue, 04/06/2010 - 02:05
Thanks I tried it, but it is giving me this error
Update Phones - Query
Begin Time : 04/06/2010 11:03:00
Query :
SET Values :
Failure Details :
name          Error Code          Error Description
SEP001360864484 Could not position within a table (informix.telecastersubscribedservice).BAT Exception : UpdatePhone::getTeleSubServicesPkids
Any suggestions
samaykhan79 Tue, 04/06/2010 - 02:14
I found this but not sure if there is fix yet, if anyone knows a fix please update this thread.
It's a bug:
Assign IP Phone Services
Add All Services From This Template
From the drop-down list box, choose the template that contains list of services that you want to update the phones with.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/bat/5_1_3/t03updph.html#wp1342091
CSCea28827 Bug Details
BAT to support subscribing users to PAB and Fast Dial Services
Symptom:
Cannot subscribe the users to IP Phone services like Personal Address Book
and Fast Dials through BAT. This applies to any IP Phone services.
Conditions:
The problem exists in all the BAT versions
Workaround:
None
weavermj1982 Tue, 02/15/2011 - 01:30
Did anyone find a resolution to this bug? I need to bulk add services to around 800 phones.
Related Content
