Warning message
EIGRP authentication issue
Answered Question
Apr 6th, 2010
I want to implement eigrp md5 authentication between one Cisco 3750 Catalyst Switch and an other Cisco 3560 Catalyst.
Routing is defined correctly with the autonomous system 10. Key Chains are created on the two switches.
I have implemented these commands on the relative interfaces :
ip authentication key-chain eigrp 10 EIGRP_KEYS
ip authentication mode eigrp 10 md5
When I issue debug ip packets , I can see that the md5 authentication don't take effect.
What I discovered, that all is ok on the 3750 switch, but on the 3560 switch, the command ip authentication key-chain eigrp 10 EIGRP_KEYS is delteled from the interface config.
Even I tried to enter this config again, but at any time, this config is systematicly deleted, causing the md5 eigp authentication to fail.
I rebooted the switch, but without any result, the problem is the same.
I am using the c3560-advipservicesk9-mz.122-44.SE1.bin IOS image on the Catalyst 3560. It there a known bug about this ?
If not, how can I fix this ?
Regards.
Correct Answer by Jon Marshall about 7 years 4 months ago
enaforhmd wrote:
Hi ganeshh.iyer ,
Thank you for your reply.
The link you provided is the same I used to implement my cnfig.
Concerning eigrp plain text authentication, I think that it's not supported.
Reagrds.
You are right, plain text authentication is not supported in EIGRP.
This sounds like the bug you are facing -
CSCsm26406 Bug Details Bug #39 of 63 | < Previous | Next >
WI08:  EIGRP authentication not working
Symptom:
The switch does not take the "ip authentication key-chain eigrp"
command.  When this command is issued there is no error message
given so it appears that it is accepted.  However when doing a show
run under the interface, the command is not there.  Issuing this command
also removes the "ip authentication mode eigrp" command.  The result is
that eigrp authentication does not work.
Conditions:
This problem was observed on 3750-ME and 3750E running 12.2(44)SE.
Workaround:
There is no workaround.
Status
Fixed
Severity
3 - moderate
Last Modified
In Last Year
Product
Cisco IOS software
Technology
IP Routing
1st Found-In
12.2(0.0.15)SE1
      Known Affected Versions This link will launch a new window.
Fixed-In
12.2(44)SE2
12.2(46.3)SID12
12.2(44)SE2
12.2(50.1)SIN
12.2(50)SG
12.2(46)SG1
12.2(52)SG
12.2(50)SG3
12.2(53)SG
12.2(52)XO
12.2(50)SG5
Interpreting This Bug
           Bug Toolkit provides access to the latest raw bug data so you have the earliest possible knowledge of bugs that may affect your network, avoiding un-necessary downtime or inconvenience. Because you are viewing a live database, sometimes the information provided is not yet complete or adequately documented. To help you interpret this bug data, we suggest the following:
  • This status of this bug is fixed. The problem described in the bug report is "fixed-in" all release versions targeted to be fixed, and all changes have been successfully tested.
  • Check for a software release later than these listed in the "Fixed-in" versions in software download center.
  • The "fixed-in" version may not be available for download yet until all the other bugs targeted to be fixed for that major release are processed. No release date information is available to Bug Toolkit. Please check the software download section frequently to look for a new version.
  • Sometimes the bug details, when available, contain the "fixed-in" version information or link to the upgrade or patch.
  • Always check the software release notes before performing any upgrade to understand new functionality and open bugs not yet fixed.
  • Any "workaround" listed in the bug details section is generally provided as a way to circumvent the bug until the code fix has been completed; often in lieu of downgrading to a non-affected version of code.
  • In certain rare circumstances, we are unable to fix the bug in all versions in which it is found. The bug will still have a 'fixed' status. Please open a service request with the Technical Assistance Center if you are being impacted by a bug in this condition.
  • Obscure version references are usually internal builds and may never be posted as a full release. Please watch for a release version later than the interim build displayed.
  • This bug has a Moderate severity 3 designation. Things fail under unusual circumstances, or minor features do not work at all, or things fail but there is a low-impact workaround.
  • This is the highest level for documentation bugs.  (Bug Toolkit may not provide access to all documentation bugs.)
  • This bug may not affect the IOS-running product you selected but is provided as a possible match. Remember IOS bugs are rarely platform-specific but all platforms do not necessarily allow the use of all the features included in a given IOS release. For this reason, Bug Toolkit could display a bug that obviously doesn't affect your platform.
  • This bug may not affect your version but was returned as a likely possibility since it was introduced but not fixed within the version range you are searching (See Known Affected Versions link.)
  • Severity levels are designated by the engineering teams working on the bug. Severity is not an indication of customer priority which is another value used by engineering teams to determine overall customer impact.
  • Bug documentation often assumes intermediate to advanced troubleshooting and diagnosis knowledge. Novice users are encouraged to seek fully documented support documents and/or utilize other support options available.
  • There is no workaround other than to upgrade.
    Jon
    Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
    Overall Rating: 5 (1 ratings)
    Ganesh Hariharan Tue, 04/06/2010 - 01:08
    • Purple, 4500 points or more
    • Community Spotlight Award,
      Member's Choice, February 2016
    Regards.
    Have tried with plain text authentication on your routers,is this working or not and are you configuring the as the below mentioned step like first authentication mode and then the key chain.
    Check out the below link for step by step configuration of authentication of eigrp in routers
    http://www.cisco.com/en/US/tech/tk365/technologies_configuration_example09186a00807f5a63.shtml
    Hope to Help !!
    Ganesh.H
    Remember to rate the helpful post
    enaforhmd Tue, 04/06/2010 - 01:20
    Hi ganeshh.iyer ,
    Reagrds.
    Correct Answer
    Jon Marshall Tue, 04/06/2010 - 02:15
    • Hall of Fame,
      Founding Member
    • Cisco Designated VIP,
      2017 LAN, WAN
    enaforhmd wrote:
    Hi ganeshh.iyer ,
    Reagrds.
    Symptom:
    Conditions:
    Workaround:
    Status
    Fixed
    Severity
    3 - moderate
    Last Modified
    In Last Year
    Product
    Cisco IOS software
    Technology
    IP Routing
    1st Found-In
    12.2(0.0.15)SE1
    Fixed-In
    12.2(44)SE2
    12.2(46.3)SID12
    12.2(44)SE2
    12.2(50.1)SIN
    12.2(50)SG
    12.2(46)SG1
    12.2(52)SG
    12.2(50)SG3
    12.2(53)SG
    12.2(52)XO
    12.2(50)SG5
    Jon
    enaforhmd Tue, 04/06/2010 - 03:22
    Hi jon.marshall,
    You are right.
    After an IOS image uppgrade, the bug is fixed.
    EIGRP authentication works fine !!!.
    Many Thanks.
