Broadcast prevention on switch
Apr 6th, 2010
HI,
                 I am getting some broadcast problems at some sites with L2 and L3 switches.Actually at each site both L2 and L3 switches are connected with non-manageable switches or hubs , so i m getting to much broadcast packets on those interfaces. I have tried to stop this with storm-control feature and then with ACLs. In ACL i have denied 255.255.255.255 and even broadcast IP of those subnets but still the broadcast packets are coming with same pace. I have also tried flow control but no gain in it. Plz help me to sort out this issue.
Taran
Ganesh Hariharan Tue, 04/06/2010 - 02:05
HI,
Taran
Hi Taran,
Have you tried configuring storm-control broadcast on switch port, check out the below link for more information about the same :-
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/storm.html
Hope to help !!
Ganesh.H
tarnhundal Tue, 04/06/2010 - 02:41
HI Ganesh,
                         I have tried this method but didnt get result. Even I set storm control for broadcast to 0.0.
thanks
Taran
Leo Laohoo Tue, 04/06/2010 - 17:07
Get rid of your un-managed switch and hub.  It doesn't matter what commands you've got if these devices are there.  In the end, the broadcast can kill your switches.
Disable spanning-tree portfast and enable spanning-tree bpduguard enable.
tarnhundal Wed, 04/07/2010 - 01:20
portfast is not enabled on that int and there is hub . I dont think BPDU guard will help in this because hub doesnt send bpdu. plz let me know other solutions.
regards,
Taran
tarnhundal Wed, 04/07/2010 - 01:36
Thanks for reply. Actually the problem is I cant bind only one MAC because there may be more IP addresses because I have already given a IP pool to that LAN segment.
