VPN Question
Answered Question
I am creating a VPN between a Juniper and PIX 8.x
I have successfully created the tunnel between remote network (Juniper 10.160.0.0/16) and local network (PIX 10.118.0.0/16) using the command sysopt conneciton permit-VPN and hosts on both networks can ping each other.
Now I want to restrict access via the tunnel so that remote host 10.160.2.70 has only access to local host 10.118.10.102
Can this be achived using the crypto ACL's ? or do I need to issuse the no sysopt conneciton permit-vpn command and then set up an ACL on the PIX outside interface to only allow 10.160.2.70 onto the local networ?? do I also need to configure the ACL to allow incoming IPSEC traffic from the remot host peer???
any help or examples would be appreciated.
Rod
Correct Answer by Jennifer Halim about 6 years 11 months ago
No, you do not have to disable the sysopt connection permit-vpn command.
This vpn-filter is applied to the tunnel-group for Juniper.
Overall Rating: 5 (1 ratings)
Jennifer Halim Tue, 04/06/2010 - 02:18
  • Cisco Employee,
You can configure vpn-filter to only allow traffic from remote host 10.160.2.70 to local host 10.118.10.102.
Example:
access-list juniper-filter permit ip host 10.160.2.70 host 10.118.10.102
group-policy juniper-policy internal
group-policy juniper-policy attribute
     vpn-filter value juniper-filter
tunnel-group general-attributes
     default-group-policy juniper-policy
Hope that helps.
Correct Answer
Jennifer Halim Tue, 04/06/2010 - 02:33
  • Cisco Employee,
