04-06-2010 02:27 AM - edited 03-15-2019 10:07 PM
I have setup a pickup group on callmanager 4.3 and used the drop down to add it to all the lines in the group
However when tested by calling one of the numbers and trying to pick up from one of the other phones in the same pickup group by Lifting the hand set, press “more” then GPickup. At this point you hear 2 beeps then nothing
Any Ideas what could be cauing this?
Solved! Go to Solution.
04-06-2010 02:38 AM
Hi Alistair,
I think the only problem here is that the users are pressing GPickup instead
of Pickup. GPickup is used in a different scenario
Cheers!
Rob
04-06-2010 02:38 AM
Hi Alistair,
Cheers!
Rob
04-09-2010 07:01 AM
Many Thanks Rob
