Change Speed and duplex on Ipphone
Answered Question
Apr 6th, 2010
We have IPphone in a branch and we want change speed and duplex in remote.
Maybe you know how to change this option of speed and duplex with CCMadmin with BAT ?
Thanks in advance
regards
Tom
Correct Answer by Aaron Harrison about 7 years 1 month ago
It's not possible to do this with BAT; it's a property you would need to configure on each handset.
There is a tool available that can allow you to do this remotely, but still manually:
https://supportforums.cisco.com/message/1164373#1164373
There are a number of similar posts on the forum already; in general I would not recommend that you do this as you can guarantee that administrative inconsistencies between the PCs, phones, and switch ports on the customer's site will create more problems that it solves.
https://supportforums.cisco.com/search.jspa?peopleEnabled=true&userID=&c...duplexphone
Aaron
Please rate helpful posts...
Overall Rating: 5 (1 ratings)
Correct Answer
Aaron Harrison Tue, 04/06/2010 - 03:32
  • Community Spotlight Award,
    Member's Choice, May 2015
Aaron
boubourse92 Tue, 04/06/2010 - 03:47
Thanks , now it's sure we can't do it .
One by one .. a really long work !
Aaron Harrison Tue, 04/06/2010 - 04:01
Yes. It will take some time to do, and leave you with a never ending admin task of continually checking the settings of each phone/PC NIC/switchport every time someone's PC slows down slightly...
Aaron
