question about ICMP and DCHP
Answered Question
Apr 6th, 2010
What are the differences between DCHP and the ICMP messages that were previously used for startup configuration? What are their strenghs?
Thx!
Correct Answer by Ganesh Hariharan about 6 years 10 months ago
Thx!
Hi ,
DHCP protocol is utilized by some network nodes to automatically retrieve their network configurations from a centralized server and icmp is a complementary protocol to IP (Internet Protocol). Like IP, ICMP resides on the Network Layer of the OSI Model.ICMP is designed for sending control and test messages across IP networks.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
Overall Rating: 5 (1 ratings)
Alexander Neupokoev Tue, 04/06/2010 - 05:19
hi.
what is DCHP ? may be DHCP ?
dhcp is dynamic host configuration protocol, using for assign ip , dns, gateway, and other options for network device.
icmp is protocol, which using for example ping (icmp type echo and echo reply). other word for test connectivity between network device.
Correct Answer
Ganesh Hariharan Tue, 04/06/2010 - 05:40
Thx!
Hi ,
Hope to Help !!
Ganesh.H
