NAC for SSL VPN Users
Apr 6th, 2010
i have a setup of NAC L2 Out of band Virtual gateway. The inside users are already working on NAC. There is a new requirement for posture assesment of
SSL VPN users. I think that the users are multiple hops away so is that possible to configure the NAC as L2 and L3 at the same time.
Moreover i have oob setup. How the VPN user will be taken by OOB setup.
Nevin Absher Thu, 04/08/2010 - 06:23
A CAS can be configured to support L2 and L3 users at the same time, but it can only be either In-Band or Out of Band.  VPN users are only supported with an In-Band CAS.
So unfortunately for your situation you would either need to add a second CAS, or convert the one you have to In-Band.
Nevin
