Faxing to voicemail in Unity or Unity Connection
Answered Question
Apr 6th, 2010
Does Unity or Unity Connection have the capability for callers to send faxes to the users voicemail box? Or do I need something like Cisco Fax Server to do this?
-mike
Correct Answer by David Hailey about 7 years 3 weeks ago
For Unity, there is a built-in tool that can be used for limited faxing capabilities (less than 50 users, it's called Fax Util).  Outside of that, you can integrate with any number of Fax Servers.  Unity Connection only supports integration with Cisco Fax Server (aka, OpenText Right Fax) for faxing capabilities.
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Tue, 04/06/2010 - 07:09
  • Purple, 4500 points or more
Hailey
