Eompls SD Tag
Apr 6th, 2010
  • Cisco Employee,
hi All,
   i have a setup as below
CE1 -----PE1 ---------PE--- ( Sniffer )-----PE----------PE2--------CE2
PE1  to CE1
service instance 10 ethernet
  encapsulation dot1q 10
  xconnect 10.192.168.105 100 encapsulation mpls
PE2 to CE2
interface TenGigabitEthernet5/0/0
no ip address
mls qos trust dscp
  encapsulation dot1q 20
  xconnect 10.192.168.104 100 encapsulation mpls pw-class Test
No rewrites are done.
The VC type used is Type 4 ( i.e ETH VLAN )
Capturing packet at the Sniffer
When i send traffic from CE1 to CE2 i see SD tag added on the packet as 10
When i send traffic from CE2 to CE1 i see SD tag added on the packet as 20.
Can u let me know how the SD Tag is determined in the above setup?
More Info
Packet captured looks like
    [ L2 Header ] [Two Label MPLS STACK ] [CW] [ Actual Ethernet Frame ]
Actual Ethernet frame lookes like below
   [ L2 header ] [SD tag ] [ Vlan TAG from CE ] [ Data]
Thanks in advance
judebryant Tue, 04/06/2010 - 07:27
the statement "encapsulation dot1q vlan-id" defines the matching criteria to be used in order to map ingress dot1q frames on an interface to the appropriate service instance.
If the packet comes in without the vlan-id being matched to a service instance, the packet is dropped.
So in your configuration, the packets comming in are already tagged and processed across the VC.
Put your sniffer in front of the interface with the service instance configured and you will see this.
Jude Bryant
Pioneer Telephone
jjacobj Tue, 04/06/2010 - 09:49
  • Cisco Employee,
So the SD Tag Added would be is present in the "encapsulation Dot1q ".
This leaves me with one basic question
1 : What is the use of adding SD tag for VC type 4 ?
        In my setup The SD Tag gets poped when sent out towards CE
judebryant Tue, 04/06/2010 - 12:42
here are your options
vlanid 10 ===>  (mpls) <=== vlanid 20
so you would have to manipulate the vlan tags in order for acceptance at the other end
left to right...translate 10 to 20
right to left ..translate 20 to 10
Router A                          Router B
interface 1/0/1                    interface 1/0/1
vlanid 10 ===> (mpls) <=== vlanid 10
Router A
interface 1/0/1
xconnect (router b) 110 encapsulation mpls
Router B
interface 1/0/1
xconnect (routera) 110 encapsulation mpls
interface 1/0/2                    interface 1/0/1
Router A
interface 1/0/2
Router B (this will not work because you already have an encapsulation dot1q 10 defined on this interface)
interface 1/0/1
so you will have to do this
interface 1/0/1
service instance 20
encapsulation default (any tagged traffic comming in, not looking at the vlan-id, however a vlan-id other than 10 will pass thru this)
rewrite ingress tag translate 1 to 1 dot1q 10 (changing the vlan-id to 10)
xconnect (routera) 120 encapsulation mpls
In summary, vlan tags are significant only to the port.  So you can use the same vlan id on another port.
Jude Bryant
Pioneer Telephone
