Call forwarding to multiple destinations?
Apr 6th, 2010
Issue: I need to have a internal number forwarded to multiple extensions.I am running CUCM
Aaron Harrison Tue, 04/06/2010 - 07:07
A phone can have one 'Call Forward All' destination.
That destination could be a hunt group pilot if you wish.
What exactly do you want to achieve in detail?
William Bell Tue, 04/06/2010 - 07:08
You may want to have the phone forward to a Hunt Pilot. Then assign the target phones (for the forward) to a Line Group. Configure the Line Group to use "Broadcast" hunting algorithm (which means it will ring all phones). So, the procedure:
1. Identify target phones
2. Assign phones to Line Group (e.g. myLineGroup) and configure for Broadcast
3. Create a new Hunt List (e.g. myHuntList) and assign myLineGroup to the HuntList
4. Create a hunt pilot (the number you forward to from the IP phone) and assign the huntlist myHuntList
Test it out.
Please remember to rate helpful posts.
oldsbravada Tue, 04/06/2010 - 07:16
Thanks Aaron & William! I will try the Hunt Pilot
scenario - update to follow.
