DMP 4400G - transitions between ads
Apr 6th, 2010
Greetings - I have a series of about a dozen 30 second ads running on the DMP 4400G. Is there a way to change the transitions between each ad, say either a smooth fading transition or just a cut to the next? At the moment there's a 2 or 3 second white screen while the next ad loads which looks a little distracting.
thanks
Tomas De Leon Thu, 04/08/2010 - 17:23
  • Cisco Employee,
* Try enabling caching on the DMP
* Another option is deploying the the playlist locally to the DMP
Cheers
T.
Szechwan649 Fri, 05/07/2010 - 16:28
Thanks for the advice. Enabling caching did not make a difference and I will try deploying locally to the DMP hopefully soon. In the meantime I have consolidated all ads into one flash file which works quite well. Some other improvements I found were that running flash ads in a small zone rather than full screen improves motion performance.
Tomas De Leon Wed, 05/12/2010 - 10:39
  • Cisco Employee,
Raschid,
I continued to research this and in addition to what you already have done
I found some more information related to your issue.
There is a known issue with transition issues between contents in a playlist.
Defect Information:
CSCtd44817-Transition time is 5-7 seconds between two videos
The problem will be addressed in the next firmware release but there are some
workarounds:
1. Create a Larger File or combine content items.
2. Problem is related to syslog misconfigured in default configuration causing
    browser to block.   This can be worked-around by the following MIB changes:
    init.syslog_collector          change to 127.0.0.1 (Default is 192.168.1.1)
    Using DMPDM:
    If syslog is disabled, enable it and set the syslog server
    address to 127.0.0.1, disable it, save and restart the DMP.
    Using DMM:
    create a task to change the syslog server address to 127.0.0.1
    and deploy to all DMPs.
3. Disabling video failover will improve transition time.
I Hope this Helps!
T.
Related Content
