04-06-2010 07:32 AM - edited 03-06-2019 10:29 AM
Can anyone tell me what the difference is between adding the "server..." line and not adding it when doing Radius authentication?
aaa new-model
aaa group server radius ADMINS
server 172.23.16.20 auth-port 1645 acct-port 1646
Compared to:
aaa new-model
2 different switches but RADIUS is working fine on both of them. the second one does not have the "server...." line.
TIA
Solved! Go to Solution.
04-06-2010 12:25 PM
Hello DPatten,
>> Radius servers are defined in the global config on both switches:
as it could be expected
you could refer to the radius group of server in AAA methods lists instead of using the individual servers
That's all !
see it as an additional level of abstraction that you can use or not
you can check looking at aaa lines
sh run | inc aaa
see configuration guide
section
Hope to help
Giuseppe
04-06-2010 11:05 AM
Hello Dpatten,
in first case a group of Radius servers is defined with one member that defined by the server line
multiple members could be defined in the group of server using other server ... lines
This does not forbide the use of older syntax to define a standalone radius server in global config.
I would expect second swich to have a radius server defined in global config and to use it for AAA
In other words in second switch it is defined an empty group of RADIUS servers
I would check with
sh run | inc radius
to see this
otherwise some external entity should tell the ip address of an active Radius server but I'm not aware of this option
Hope to help
Giuseppe
04-06-2010 11:20 AM
Giuseppe
radius-server host 172.23.16.20 auth-port 1645 acct-port 1646 key 7 xxxxxxxxxxxxxxxxxxx
radius-server host 172.23.16.22 auth-port 1645 acct-port 1646 key 7 xxxxxxxxxxxxxxxxxxx
So if I don't have any specified in the aaa but do have them specified in the global config it obviously works fine. If I specifically put them in the aaa group it will use only the ones I specify?
04-06-2010 12:25 PM
Hello DPatten,
That's all !
sh run | inc aaa
section
Hope to help
Giuseppe
