lan-to-lan tunnel issues
Apr 6th, 2010
All,
Having intermittent issues where a l2l tunnel will come up and have traffic in only one direction. l2l tunnels are between a 5510 and one of my 5505's. Restarting the 5505 seems to have no effect.The tunnel us set up so that it can be brought up by either end.
I have re-created the tunnel in question on the 5510 but the only thing that seems to bring it back is to restart the 5510.
Thoughts?
Jeff
Jennifer Halim Tue, 04/06/2010 - 22:26
Things that you can check is if there is overlapping crypto access-list with other tunnels, and also if dynamic crypto map is at the bottom of the crypto map sequence.
