Interesting destination-pattern regex puzzle
Answered Question
Apr 6th, 2010
Hi Experts,
I am trying to write a single regular expression for the destination-pattern command to match all 4 digit numbers except 41XX and 42XX ?
Can you pelase help me?
Bala.
Correct Answer by William Bell about 6 years 10 months ago
Funny.  Sorry, I just assumed you were concerned with the 4xxx range.  Anyway, for this you will need two dial-peers.
To match: 1000-4099 and 4300-9999
One dial-peer destination pattern: 4[0,3-9]..
The other dial-peer destination pattern: ^0^4...  (which means that the first digit can't be a 0 or a 4)
HTH.
Bill
Overall Rating: 4.5 (3 ratings)
balasundaram.k_2 Wed, 04/07/2010 - 01:18
Hi Bill,
Thanks a lot for your reply and the link.
destination-pattern 4[0,3-9] will match only numbers in the raneg 40XX and 43XX-49XXX.
I ws looking for a single destination pattern that will match all 4 digit extensions except 41xx and 42xx (all numbers in the range 1000-4099 and 4300-9999).
Any ideas on constructing the desired range using a single reg-ex?
Bala.
Correct Answer
William Bell Wed, 04/07/2010 - 06:32
HTH.
Bill
