Vlans on The supervisor 720
Answered Question
Apr 6th, 2010
Hello friends, is it possible to use the Two Gigabit Ethernet ports on a RSP720-3C and assing them a VLAN?...Thanks for your help in advance.
Correct Answer by Collin Clark about 7 years 2 months ago
Yes you can. Configure it as a normal switch port.
Hope it helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Tue, 04/06/2010 - 14:05
  • Purple, 4500 points or more
Hope it helps.
