IPS Module (NME-IPS-K9) on ISR Router CPU High
Apr 6th, 2010
We have IPS module (NME-IPS-K9) on 3845 ISR router. All the time we see out of two CPUs on it, one CPU is always 100%. Can someone advise it this is normal behavior or is it due to some configuration/software error?.
This situation is same before and after upgrade of IPS module.
Attached is the sreenshot for your information.
Jennifer Halim Wed, 04/07/2010 - 05:35
CPU 100% on the NME-IPS module is normal. It will always show 100%. CPU on IPS is not related to the inspection load.
To check if the IPS module is overloaded, please check the "Inspection Load" speedometer.
