ASA 5510 & ASA 5505 VPN
Answered Question
I have an ASA 5510 in HQ (Version 8.0(3)) and an ASA 5505 (Version 8.3(1)) at remote end.  I am utilizing easy vpn.  The vpn works great, but when the VPN is connected the 5510 shows 17 IPSEC connections for this one device.  I look at the 5505, and it is saying 1.
Thanks!
Correct Answer by Jennifer Halim about 7 years 3 weeks ago
Yes, it will create SAs for every subnet you have, one SA pairing with the remote subnet of ASA 5505, and one SA pairing with the peer ip of the remote ASA 5505.
It creates the extra SA pair with the peer ip address of the remote ASA for easy vpn (it's normal in easy vpn). If you configure LAN-to-LAN between the 2 ASAs, it will just be half the number of SAs as there won't be SA created for the peer ip address like in easy vpn tunnel.
Here is the SAs pairing created:
local ident (addr/mask/prot/port): (64.196.6.165/255.255.255.255/0/0)
remote ident (addr/mask/prot/port): (64.196.6.180/255.255.255.255/0/0)
local ident (addr/mask/prot/port): (172.30.20.0/255.255.255.0/0/0)
remote ident (addr/mask/prot/port): (192.168.101.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.30.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.70.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.71.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.80.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.81.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (172.30.88.0/255.255.255.0/0/0)
local ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
Overall Rating: 5 (1 ratings)
Federico Coto F... Tue, 04/06/2010 - 20:22
  • Green, 3000 points or more
I've seen this before with EzVPN (seems to be very persistent).
If you clear the tunnel and bring it iup again, you see the same behavior?
If that's so, can you post both configs?
Federico.
Jennifer Halim Tue, 04/06/2010 - 21:28
  • Cisco Employee,
Is the HQ ASA terminating multiple easyvpn connections? Also, do you have any remote access vpn client terminating on the HQ ASA as well? if they are, then it will be showing multiple IKE/IPSec.
Currently the HQ is only terminating one easyvpn connection (will be more once I get this figured out).
I do have multiple clients terminating to the VPN.
What I want to make clear is the easyvpn connection will make 1 IKE tunnel and 17 IPSEC tunnels, when I pull the plug on the unit, you can see it drop back to a 1-1 on the HQ for the vpn clients.
See attached.
Jennifer Halim Wed, 04/07/2010 - 05:38
  • Cisco Employee,
Please share the output of "show crypto ipsec sa peer " on the HQ ASA5510.
This is the crypto from the 5510 for the 5505
asa# sh crypto ipsec sa peer 64.196.6.180
peer address: 64.196.6.180
    Crypto map tag: SYSTEM_DEFAULT_CRYPTO_MAP, seq num: 65535, local addr: 64.196.6.165
      current_peer: 64.196.6.180, username:
      dynamic allocated peer ip: 0.0.0.0
      #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
      #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
      #pkts compressed: 0, #pkts decompressed: 0
      #pkts not compressed: 0, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: 64.196.6.165, remote crypto endpt.: 64.196.6.180
      path mtu 1500, ipsec overhead 74, media mtu 1500
      current outbound spi: 31B990D0
    inbound esp sas:
      spi: 0x7CD49785 (2094307205)
         transform: esp-aes esp-sha-hmac none
         in use settings ={RA, Tunnel, }
          slot: 0, conn_id: 2338816, crypto-map: SYSTEM_DEFAULT_CRYPTO_MAP
         sa timing: remaining key lifetime (sec): 28631
         IV size: 16 bytes
         replay detection support: Y
    outbound esp sas:
      spi: 0x31B990D0 (834244816)
         IV size: 16 bytes
      current outbound spi: 5724A440
    inbound esp sas:
      spi: 0x23C29273 (599954035)
         sa timing: remaining key lifetime (sec): 28632
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x5724A440 (1462019136)
         IV size: 16 bytes
      current outbound spi: 7319F5DD
    inbound esp sas:
      spi: 0xD7E38EE9 (3622014697)
         sa timing: remaining key lifetime (sec): 28629
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x7319F5DD (1931081181)
         IV size: 16 bytes
      current outbound spi: 05C48316
    inbound esp sas:
      spi: 0xF51CFD49 (4112317769)
         sa timing: remaining key lifetime (sec): 28628
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x05C48316 (96764694)
         IV size: 16 bytes
      current outbound spi: B3FDC508
     inbound esp sas:
      spi: 0x1D3C2C54 (490482772)
         sa timing: remaining key lifetime (sec): 28626
         IV size: 16 bytes
    outbound esp sas:
      spi: 0xB3FDC508 (3019752712)
         IV size: 16 bytes
      current outbound spi: 130D6E8E
    inbound esp sas:
      spi: 0x68DFF375 (1759507317)
         sa timing: remaining key lifetime (sec): 28625
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x130D6E8E (319647374)
         sa timing: remaining key lifetime (sec): 28623
         IV size: 16 bytes
       current outbound spi: C0A94DAC
    inbound esp sas:
      spi: 0x673C5702 (1732007682)
         sa timing: remaining key lifetime (sec): 28622
         IV size: 16 bytes
    outbound esp sas:
      spi: 0xC0A94DAC (3232320940)
         IV size: 16 bytes
      current outbound spi: 2D783439
    inbound esp sas:
      spi: 0xD499DFD9 (3566854105)
         sa timing: remaining key lifetime (sec): 28621
         IV size: 16 bytes
    outbound esp sas:
       spi: 0x2D783439 (762852409)
         sa timing: remaining key lifetime (sec): 28620
         IV size: 16 bytes
      current outbound spi: BCD61AC9
    inbound esp sas:
      spi: 0x76D18AEA (1993444074)
         sa timing: remaining key lifetime (sec): 28619
         IV size: 16 bytes
    outbound esp sas:
      spi: 0xBCD61AC9 (3168148169)
         IV size: 16 bytes
      current outbound spi: 4A4CD1CF
    inbound esp sas:
      spi: 0xCDBFC162 (3451896162)
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x4A4CD1CF (1246548431)
         sa timing: remaining key lifetime (sec): 28618
         IV size: 16 bytes
      current outbound spi: 3B4876DE
    inbound esp sas:
      spi: 0x88488E6A (2286456426)
         sa timing: remaining key lifetime (sec): 28617
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x3B4876DE (994604766)
         IV size: 16 bytes
      current outbound spi: 04EBDD5F
    inbound esp sas:
      spi: 0xA5641A72 (2774801010)
          sa timing: remaining key lifetime (sec): 28616
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x04EBDD5F (82566495)
         IV size: 16 bytes
      current outbound spi: 148326FE
    inbound esp sas:
      spi: 0x25F19BCA (636591050)
         sa timing: remaining key lifetime (sec): 28615
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x148326FE (344139518)
         IV size: 16 bytes
      current outbound spi: EF7D0BA1
    inbound esp sas:
      spi: 0x3C811E67 (1015094887)
         sa timing: remaining key lifetime (sec): 28613
         IV size: 16 bytes
    outbound esp sas:
      spi: 0xEF7D0BA1 (4017949601)
         IV size: 16 bytes
      current outbound spi: 0221694F
    inbound esp sas:
      spi: 0x35D46FD9 (903114713)
         sa timing: remaining key lifetime (sec): 28612
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x0221694F (35744079)
          IV size: 16 bytes
      #pkts encaps: 27, #pkts encrypt: 27, #pkts digest: 27
      #pkts decaps: 31, #pkts decrypt: 31, #pkts verify: 31
      #pkts not compressed: 27, #pkts comp failed: 0, #pkts decomp failed: 0
      current outbound spi: 412AC6F8
    inbound esp sas:
       spi: 0xE2254D63 (3794095459)
         sa timing: remaining key lifetime (sec): 28610
         IV size: 16 bytes
    outbound esp sas:
      spi: 0x412AC6F8 (1093322488)
         IV size: 16 bytes
      current outbound spi: DDE92DD6
    inbound esp sas:
      spi: 0xD67A60FC (3598344444)
         sa timing: remaining key lifetime (sec): 28609
         IV size: 16 bytes
    outbound esp sas:
      spi: 0xDDE92DD6 (3723046358)
         sa timing: remaining key lifetime (sec): 28608
         IV size: 16 bytes
asa#
Correct Answer
Jennifer Halim Wed, 04/07/2010 - 06:01
  • Cisco Employee,
Jennifer Halim Wed, 04/07/2010 - 06:12
  • Cisco Employee,
Unfortunately, it is just the behaviour of easy vpn, as it will show 1 SA for the LAN subnet, and another SA for the peer address.
No, it will not affect the license. IPSec license is based on the number of peers, not the number of SAs.
