vlans and hsrp problem
Answered Question
Apr 6th, 2010
i have two catalyst 6509 (switch A and Switch B) with portchannel and hsrp between them, i have some vlans configured in both, but my problem is when the active interface (switch A) going down, the standby interface (switch B) don`t becomes active until i put the interface in shutdown and the no shutdown, is the only way that become active and the interface vlan going to up
the ios is 12.2(33)SXH5
any idea?
thanks
Correct Answer by Jon Marshall about 6 years 10 months ago
Okay, apart from vlan 98 on switch B it all looks okay.
So which interfaces are you having issues with ?
Are all the vlans allowed across the etherchannel trunk ?
Could you shutdown one of the active vlan interfaces on switch A and then post "sh standby "
Jon
Correct Answer
Jon Marshall Tue, 04/06/2010 - 16:23
Jon
erodrig Tue, 04/06/2010 - 16:56
hi
the problem is specially with the interface vlan 104, the vlan allowed on etherchannel are 13,100,185,194,222,223
there is no vtp domain, the switches are in transparent mode and the switches from idf are foundry, here`s a diagram.
unfortunately i can`t shut any interface because the equipment are in production, do you think that maybe the issue is in the IDF (foundry) equipment?
i will try to get the config from them
thanks
Jon Marshall Tue, 04/06/2010 - 16:58
erodrig wrote:
hi
thanks
You need to allow vlan 104 on the etherchannel so that the 2 switches can send HSRP packets for that vlan to each other.
Jon
