Cisco Phone Application Suite for different ring tone for each line
Apr 6th, 2010
This is Vikram.
We have around 2000 PI phones and we have  requirement received from customer that they need different ring tone  for every line of IP phone.
I don't know this is possible or not if it is possible please send me the link how can I configure using  Cisco Phone Application Suite
Cheers,
Vikram
David Hailey Thu, 04/08/2010 - 16:01
  • Purple, 4500 points or more
This is something that users can configure themselves directly on the IP phone.  When they go into the ring settings, you can select a default ring tone which will default to all lines OR you can choose each line individually and set a different tone for each line.  Again, this is a user configuration - not an administrative one.
Hailey
Please rate helpful posts!
paolo bevilacqua Fri, 04/09/2010 - 11:33
  • Hall of Fame,
    Founding Member
Since your profile indicates you are a Cisco employee, I would suggest you use the many resources internally avaiable to you, to not give readers the impression that is you best support is an external customers' forum.
