3GE-GBIC-SC: Unable to install 128 Packet Memory (4 x 128)
Apr 6th, 2010
3GE-GBIC-SC NO. 1:
SLOT 4  (RP/LC 4 ): 3 Port Gigabit Ethernet
  MAIN: type 68,  800-6376-05 rev C0
        Deviation:  D063031, D062881, D048296
        HW config: 0x00    SW key: 00-00-00
  PCA:  73-4775-07 rev D0 ver 2
        Design Release 2.0  S/N XXXXXXXX
  MBUS: Embedded Agent
        Test hist: 0x00    RMA#: 00-00-00    RMA hist: 0x00
  DIAG: Test count: 0x00000000    Test results: 0x00000000
  FRU:  Linecard/Module: 3GE-GBIC-SC=
        Processor Memory: MEM-GRP/LC-128=
        Packet Memory: MEM-LC1-PKT-256=
  L3 Engine: 2 - Backbone OC48 (2.5 Gbps)
  MBUS Agent Software version 1.117 (RAM) (ROM version is 3.47)
  ROM Monitor version 16.12
  Fabric Downloader version used 10.1 (ROM version is 10.1)
  Primary clock is CSC 1
  Board is analyzed
  Board State is Line Card Enabled (IOS  RUN )
  Insertion time: 00:10:52 (00:03:03 ago)
  Processor Memory size: 134217728 bytes
  TX Packet Memory size: 134217728 bytes, Packet Memory pagesize: 8192 bytes
  RX Packet Memory size: 134217728 bytes, Packet Memory pagesize: 8192 bytes
  0 crashes since restart
3GE-GBIC-SC NO. 2:
SLOT 5  (RP/LC 5 ): 3 Port Gigabit Ethernet
  MAIN: type 68,  800-6376-01 rev E0
        Deviation: 0
  PCA:  73-4775-02 rev E0 ver 2
        Design Release 2.0  S/N AAAAAAAA
        Packet Memory: MEM-PKT-512-UPG=
  MBUS Agent Software version 1.117 (RAM) (ROM version is 2.32)
  ROM Monitor version 16.6
  Board is analyzed
  Insertion time: 00:05:11 (00:03:58 ago)
  TX Packet Memory size: 268435456 bytes, Packet Memory pagesize: 16384 bytes
  RX Packet Memory size: 268435456 bytes, Packet Memory pagesize: 16384 bytes
-------QUESTION-------
We tried to install the 6 packet memory modules of 3GE-GBIC-SC NO. 2 to 3GE-GBIC-SC NO. 1 but the 3GE-GBIC-SC NO. 1 did not sync with the GRP-B. It seems that 3GE-GBIC-SC NO. 1 does not accept any packet memory modules higher than 256MB. Do we have to upgrade the firmware/version of the hardware? If yes, kindly provide us the procedure or any link on how to do upgrade the hardware.
Thank you and regards,
Giuseppe Larosa Fri, 04/16/2010 - 03:57
Hello Alfad,
I see that the linecard that accepts the 512 MB packet memory is version E0 and it is newer then the other one
also take in account memory chips location on engine2
http://www.cisco.com/en/US/docs/routers/12000/gsr_linecards/enet_lc/installation/guide/enet_lc.html#wp651093
check memory on linecards
http://www.cisco.com/en/US/docs/routers/12000/gsr_linecards/enet_lc/installation/guide/enet_lc.html#wp651420
3GE datashet says that packet memory can be upgraded to 512 MB regardless of version
http://www.cisco.com/en/US/products/hw/modules/ps2710/products_data_sheet09186a0080092085.html
so the version or revision should not be a problem
Hope to help
Giuseppe
Related Content
