6500 Boot problem
Apr 7th, 2010
Hi All,
  I have 6509 switch withc sup720. I set the bootvar then reboot the switch,  the switch can boot successfully. But if i trun off  the switch and turn on i find the bootvar settings is gone.
Any body knows what is the reason ?
Jon Marshall Wed, 04/07/2010 - 03:26
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Have you tried setting this in the running config -
6500(config)# boot system flash
make sure if you have other boot system flash commands in your running config that the one above is first in the list. You can do this ny deleting existing ones, entering the one above and then entering the other ones again if needed.
Do a wr mem and then reload the switch.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
