Remote Desktop to vpn client
Apr 7th, 2010
   We have slaes engineers using cisco remote vpn client on their laptops. They access our database application over vpn. They do not have internet access once they connect to our asa (vpn access to network). Sometimes they have some issues regarding accessing database application. Is it possible to do remote desktop or teamviewer from my PC ( inside network) back to them ( over vpn access with no internet) to help them?
Hope the scenario is clear, please let me know if someone need more clearer picture.
Ahmed...
Jon Marshall Wed, 04/07/2010 - 03:39
Ahmed...
Ahmed
Do you mean allow them to run remote desktop to your PC and then from your PC access the database application ? If so yes this is perfectly possible, we used to allow remote desktop access for this very sort of thing.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
ahmed.gadi Wed, 04/07/2010 - 03:53
Thanks Jon,
                No my requirement is in reverse way
Users' desktop logged in via VPN need to be access by network admin, so that administrator can help users to solve users' problem.
Hope it clears your doubt
Ahmed...
ahmed.gadi Thu, 04/08/2010 - 13:37
Hi all,
        I have solved the problem with NAT0 help.
Ahmed
stevechapman_2 Tue, 07/26/2011 - 09:10
Ahmed,
Can you explain how you resolved this issue.  I have the same problem my vpn users can remote desktop to any inside pc, but users inside cant vpn to them.
thanks
Steve Chapman
