How to call CVP VXML Script from ICM
Overall Rating: 5 (1 ratings)
The VXML server comes with the 2 port evaluation licence and a working application called "HelloWorld". The first test you should make is to have ICM invoke "HelloWorld" - the spelling must be correct, case sensitive.
You can tell if the VXML Server can run the application by using your browser.
http:// ADDRESS>:7000/CVP/Server?application=HelloWorld
should return a page of VXML. Check VXMLServer\admin\status.bat and it should show that one person is in the application HelloWorld.
Then call http:// ADDRESS>:7000/CVP/Server?audium_action=hangup
will return the disconnect page of VXML data and drop the call, and now status should show no callers in the application.
REgards,
Geoff
