SIP DN "call forward all" supplementary-service
Apr 7th, 2010
we try to setup a sip account with cucme 8.0.
it seems to work good but supplementary-service is not working and codec is a problem.
we cannot set call-forward all with sip.
we use g711 alaw codec for sip and with this codec it is not possible to access the voicebox.
since sip is using alaw and dial-peer to unity uses ulaw.
we use voice-class codec with sip but if alaw is used access to voicebox is not possible.
Here is the configuration:
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
fax protocol pass-through g711alaw
  h225 timeout setup 3
  registrar server expires max 1200 min 300
  no update-callerid
voice class codec 2
codec preference 1 g726r32
voice class codec 1
codec preference 1 g711alaw
codec preference 2 g711ulaw
codec preference 3 g729r8
voice register global
mode cme
source-address port 5060
max-dn 88
max-pool 22
authenticate register
dialplan-pattern 1 .T extension-length 2
voicemail 99
create profile sync 3100072181378111
voice register dn  1
number 45
call-forward b2bua busy 72
call-forward b2bua mailbox 99
call-forward b2bua noan 72 timeout 10
allow watch
name phone1
label phone1
voice register dialplan 1
type 7940-7960-others
pattern 1 .
voice register pool  1
id mac 3CF7.2AAD.1FE9
number 1 dn 1
incoming called-number
dialplan 1
dtmf-relay sip-notify
voice-class codec 1
username 45 password ****
no vad
Please help me with that
arnulf.blattl Sun, 04/18/2010 - 01:53
Well codec is not a problem anymore? - i have no idea why - it is working.
What cannot be done is this "call forward all to voicemail".
if i use supplementary service from Sip Phone to do a call forward to 99 ( voicebox unity ) it is redirecting to unity.
The unity then takes the call but it goes to the voice menue instead of voicebox.
so you cant leave a message - callers will hear " please enter your pin ".
The other thing is, that the call is redirected, but it will not show in config of cucme.
This: call-forward b2bua all 99 is never set - but it is redirecting????
What is this all about?
And PLZ can someone move this post to ip telephony - Video is the wrong section.
