CUCM 7.1 DHCP Question
Answered Question
Apr 7th, 2010
  • Gold, 750 points or more
I am configuring DHCP on a CUCM 7.1.3 server and have a question re. the setup.
When configuring a server I enter settings such as primary DNS, secondary DNS, Primary TFTP, Secondary TFTP, Domain Name, ARP Cache Timeout etc.
When I add a DHCP Subnet as well as the address info there are spaces to add the settings listed above. If I leave these blank are they inherited from the server settings I configured in the previous step?
This woulkd make sense to me. Unfortunately I cannot try it as I am doing the config over a VPN.
Correct Answer by William Bell about 7 years 2 weeks ago
I configured this once as a test and if memory serves, your assumptions are correct. the DHCP subnet will inherit settings from the DHCP server.
I typically recommend not running DHCP on the CUCM cluster. Unless, you are dealing with a deployment where there is not better option. Or you are doing a relatively small deployment and the CUCM cluster is underutilized. Just a thought.
HTH.
Bill
Overall Rating: 5 (1 ratings)
Correct Answer
William Bell Wed, 04/07/2010 - 05:38
  • Purple, 4500 points or more
HTH.
Bill
James Hawkins Wed, 04/07/2010 - 06:27
Hi Bill,
Thanks for the response. It would seem logical to work this way so I will configure it and sort out any problems later.
Like you I do no like running DHCP on the CUCM servers but in this case we have little choice as we do not have access to the core switches or to the DHCP servers used for the desktop machines.
The CUCM servers are replacing CallManager 4.2 boxes which acted as the phone DHCP servers previously. The new servers are 7835's and have enough grunt to run the DHCP process.
DHCP is one thing that Windows based CCM does better than Linux CUCM - it is not even possible to put a description against the scopes!
