Enable SNMP on ASA 5505 by hostname?
Apr 7th, 2010
Dear All,
I would like to ask you about some command that enable snmp on ASA 5505.
snmp-server community public
snmp-server enable traps
snmp-server host inside 192.168.0.1
snmp-server host outside 203.10.10.1
my question is:
snmp-server host outside 203.10.10.1 so, i want to change ip to hostname but it not allow.
So how can i change to hostname bece i don't want to set public ip add.
Best Regards
rechard
Jennifer Halim Wed, 04/07/2010 - 04:30
  • Cisco Employee,
You have to configure the hostname using the "name" command prior to using the hostname in the snmp command.
Example:
name 203.10.10.1 snmp-outside
snmp-server host outside snmp-outside
Please rate and mark all answered questions. Thanks
rechard_hk Wed, 04/07/2010 - 18:43
Dear halijenn,
Thanks you for your command!!!
So my HQ they use DHCP(Public ip address) that why i would like to set domian name to point to my HQ.
Example:  snmp-server host outside abc.net
then it don't care about the public ip address i just to care about domain name only.
is it possible ?
Best Regards,
Rechard
