04-07-2010 05:12 AM - edited 03-21-2019 02:24 AM
Syslog message: LOCAL0.INFO: SPA504G 00:25:84:d8:c2:03 -- Successful resync http://secprov2.xxx.com/sipura/Configurator.aspx?type=504G&mac=002584d8c203&mode=update
contents of config file
<flat-profile>
<SIP_User_Agent_Name ua="na" >D5FRIG-$VERSION</SIP_User_Agent_Name>
</flat-profile>
17 12:52:43.271073 192.168.1.69 88.215.56.187 Syslog LOCAL0.INFO: SPA504G 00:25:84:d8:c2:03 -- Resync failed: corrupt file\n
04-07-2010 05:45 AM
i'm not sure why it's not workign in your case but i managed to get the phone provisioned in 7.4.4 using your example:
FMM >>>> Requesting profile
content len (pld) =102
SPA504G 00:25:84:d8:d0:aa -- Successful resync tftp://192.168.1.102:69/nacho_2.xml
FMM >>>> Successful profile
PRV pc=1
I have enclosed the xml file for your reference...has it been encrypted in your case? if so, did you use the SPC tool?
Thanks!
-nacho
04-07-2010 08:34 AM
I took a phone that was working fine
did the upgrade and then the provisioning started to fail
I iterated around removing content till we were left with just the xml I showed
The provisioning is from a Windows server using IIS (normally over SSL)
No other encryption is used as the content is created dynamically
can you try you example using http - I will try with tftp (which is not an option for us)
04-07-2010 08:34 AM
04-07-2010 09:08 AM
IIS uses "chunked transfer encoding" - I think it does not like that - but every other SPAXXXX (thousands of them) device works fine
I cannot see anything in the release notes about a provisioning change
04-08-2010 12:59 AM
we've tried with HTTP without any issue... what if i give you my MAC address so that i can try to get tmy phone provisioned in your setup?
04-09-2010 08:23 AM
Stand easy - we have found the issue - The 504 (not tried the 502 yet) running 7.4.4 does not like some IIS website settings (dont have the detail yet)
The scary things are
04-22-2010 05:31 AM
Have you worked out what was causing it? I've got a system on Apache and am seeing the same issue with JUST the 504, even the 508 provisions which is mad considering it looks like the same firmware file. I'm trying to rule out typos etc before I bore you lot with the details..
S
EDIT: Sorry, 508 is broken too. At least it makes more sense...
04-22-2010 06:04 AM
I can confirm the issue. I have a file that is accepted by 7.4.3 but rejected by 7.4.4 as corrupt. If someone from a Cisco address contacts steve.howes@poundbury.com I can give you a URL to provision with.
04-22-2010 02:43 PM
it was "chunked transfer encoding" in the html - nothing wrong with the XML, so must be an undocumented change to the phone browser
look at the html from your server using wireshark, you need to find a way to turn off chuncking on the server
not sure how we did it, but our xml is generated namically from an application so was done progromatically
Stuart
04-23-2010 03:44 AM
Yep, it's definately broken handling of chunked encoding. I added a Content-length header in PHP to override it's use of chunked encoding and the phone took it. Guessing the HTTP stack on the phones was upgraded and not mentioned in release notes? Either way, the fix if you use PHP is to do put all the profile into a variable rather than outputting it as you go, and then do:
header("Content-length: " . strlen($profile));
echo $profile;
04-26-2010 08:38 AM
Does Cisco have any thoughts on this?
04-26-2010 08:58 AM
Hi Steve
Sorry for the late reply, I'm checking with engineering whether there was any (undocumented) change in the HTTP stack in 7.4.4. I'll get back to you guys soon!
Thanks!
-nacho
04-26-2010 10:17 AM
I am also seeing this issue to with 7.4.4. If I drop the firmware back to 7.4.3 it provisions fine (Apache over SSL).
04-30-2010 08:46 AM
are you seeing this issue when sending only one chunk or do you see this also when sending multiple chunks?
Thanks!
-nacho
