VG248 continiously rebooting
Apr 7th, 2010
I have a VG248 gate that is continiuosly rebooting, However i have remove the gateway from production and kept it for standalone without any connectivity and then tried to boot but still  it us rebooting,
Can any one suggest what can be the issue.
Its running image 1.3....
Also plz suggest what else can be checked as i have already removed the box from production and tested it standalone i ahve also reset it to default so no configuration is there.
William Bell Wed, 04/07/2010 - 06:07
There is a menu option in the VG248 where you can view the environmental status. It will show you power and environmental information. You should check this out. I had a vg248 that was continuously rebooting and it was related to the 1.8 volts power supply. You can access the environmental status information by going to Diagnostics>Show Environment.
See the following link for more information:
