data interruption on ACL's ?
Apr 7th, 2010
We are in the middle of a migration of some services but we need to apply some kind of "basic" security and I was thinking of using ACL's.
But....
Will there be any impact on established connections ( interactive and non-interactive ) when I make changes to the ACL ?
I need to know what the impact will be on active connections when I remove the ACL from the interface ( to make changes )
I need to know what the impact will be on active connections when I apply the ACL on the interface ( after changes are made )
The connections are very sensitive ( SAP, JBOSS, MQ ) and need a reconnection when interrupted which is not an option to end-users...
Panos Kampanakis Wed, 04/07/2010 - 07:46
  • Cisco Employee,
If the connections are already established then no.
The ACL checks are done for new connections and existing ones go through the TCP state checks but not through the ACLs.
I hope it helps.
PK
