multi-domain with Cisco IP-Phone / Workstation
Apr 7th, 2010
i set up an 3560 ver.12.2 (52) SE to use 802.1X with host-mode multi-domain to get IP-Phone ( CP 7962G v04 )  and Workstation together on the same port.
I read all the guides i found on cisco.com e.g.
http://www.cisco.com/en/US/tech/tk389/tk814/technologies_configuration_example09186a00808abf2d.shtml
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_52_se/configuration/guide/sw8021x.html
The Phone is mab authenticated, Workstation PEAP.
Everything works fine, if only the workstation is connected to the port.
If hostmode is not configured, also the IP-Phone operates as a single device on the Port. Also it works if i set the host-mode to multi-host
Actually i have a problem to get both devices authenticated with multi-domain
The Switch logs that both device authenticated properly, but the IP-Phone restart the authentication every 60sec,everytime the phone passed but failed to get any connection.
Any ideas?
Thx
Sebastian
sebastiangille Thu, 04/08/2010 - 11:02
i found one mistake in an IAS-Extension configuration.
But everytime the phone passes the authentication process, the domain is set to DATA
e.g.
            Interface:  FastEthernet0/18
          MAC Address:  0021.....
           IP Address:  Unknown
            User-Name:  0021....
               Status:  Authz Success
               Domain:  DATA ( must be VOIP!!!!! )
       Oper host mode:  multi-domain
     Oper control dir:  in
        Authorized By:  Authentication Server
           Vlan Group:  N/A
      Session timeout:  N/A
         Idle timeout:  300s (local), Remaining: 117s
    Common Session ID:  0A040552000011D5E666C4C5
      Acct Session ID:  0x000012A8
               Handle:  0x290001D5
CDP and LLDP is activate on the IP-Phone
sebastiangille Mon, 04/12/2010 - 09:15
a very simple solution.
I forgot "aaa authorization network default group radius".
thananan_c Wed, 04/14/2010 - 03:07
Congrats !!!
How many IP Phones you/customer deployed with MDA mode ?
I wonder how I can manage to adding  IP Phones' MAC to RADIUS and setup EAP password on tousand of IP Phones.
sebastiangille Wed, 04/14/2010 - 03:26
i tested MAB with IP-Phones on MS IAS ( no password ) The phone authenticates with a computer-account ( AD )
EAP-MD5 ist not practical to authenticate IP Phones with MS IAS, because you must configure ActiveDirectory for reversible password ( LM-Hash ), this is highly insecure.
It is also possible to authenticate IP-Phones against ACS with EAP-MD5 or EAP-TLS - EAP-TLS is the prefered method, to avoid the EAP-MD5 "typing" password problem :-)
rtimmermans Fri, 10/29/2010 - 04:48
Hi Sebastian,
I am struggling with Microsoft NPS to do the same with phones as computer account, how did you manage to get it working?
MICHAEL CARTER Tue, 08/16/2011 - 01:05
Hello Robert,
Regarding your .1x config.  Did you manage to get the Microsoft NPS to authenticate the phones?  How did you do this?
michael.
rtimmermans Wed, 08/17/2011 - 03:03
Hi Michael,
I have examined this very thorough. I did not get Microsot NPS to authenticate the phones.
Strange thing I encountered: when a device was connected to a switch directly, NPS managed to authenticate it, But when the device whas behind a phone, NPS didn't recognize the "handshake" anymore.
Even traced it with wireshark.
Now we don't need the telephones authenticated: they have their own Voice vlan. But the switch in the phone needs to send the 802.1x authentication to the RADIUS server.
So I tried the same with Cisco ACS, and managed to get it working. The same setup.
MICHAEL CARTER Thu, 08/18/2011 - 00:55
TAC also found this bug on what I reckon is the same issue.
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCsr71675
DE has decided it is not worth fixing, which seems a bit short-sighted seeing as how many organisations are running NPS and Cisco Voice - so if anyone else really needs this then you will need to create a PER.
Next step for us is to install a Cisco ACS and try and configure the NPS to proxy to the ACS just for the phones.
sebastiangille Wed, 10/19/2011 - 09:54
Hi Robert,
sorry for this late reply on your post ( 29.10.2010 05:48 )
I authenticate the phones by MAB with IAS/ NPS with a third-party extension from rt-solutions.de
This extension make it possible, among others, to authenticate "MAB-Phones" by using computer-accounts in your AD.
