DMP 4305 Non responsive since I downgraded from 5.1 to 5.0.3
Apr 7th, 2010
voucher_base_ /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Our server is running an older version of the DMM so I had to downgrade one of our new DMPs from 5.1 to 5.0.3. Since I installed the downgrade the DMP has become non-responsive. Has anyone ran across this? If so how can you fix it, I want to try and re-install the OS but I am unable to access the DMP to run the firmware installer.
HELP! Jason
Tomas De Leon Thu, 04/08/2010 - 16:50
* Please try setting the DMP back to factory defaults.  Push the reset button on the back and hold for at least 10 seconds or to the DMP beeps and reboots.
* If that does not work,  After the  reset to factory defaults try a HARD reboot by unplugging power and reapplying power adapter.
