Hi Gear Misner,
If you log into the GUI again, and Syncronise the CUE to the CME it should come up and ask you if you want to add these users in, it will give you the option to enable CFNA and Mailboxes for those 4 users.
NOTE: The ephones must have usernames and passwords on them for the GUI to recognise them and add them.
Cheers,
David.
Cheers,
David Trad.
**When you rate a persons post, you are indicating a thank you or that it helped, but at the same time you are also helping to maintain the community spirit - You don't have to rate posts and you wont be looked down upon :) *
