stop sending the ring on fxs
Apr 7th, 2010
  • Bronze, 100 points or more
I've got an amplifier plugged into an fxs port on the UC540. I've assigned it an extension for overhead paging, when I dial the extension I here it ringing. The amplifier only amplifies the ring. If I could just dial and talk it make everything better. Anyone have an idea?
Thanks for any help
Stephanie
Marcos Hernandez Wed, 04/07/2010 - 12:03
  • Blue, 1500 points or more
Stephanie,
On an FXS port, the action of going off-hook is controlled by the station connected to it, not the port itself. Your amplifier would have to support direct connect if you want to go off-hook immediately.
Marcos
