creating rules on cisco pix
par13
Could anyone help me to create a few basic rules that will allow this traffic to flow thru the cisco pix firewall?
internal networks:
192.168.1.0/24
192.168.2.0/24
both needs to be able to search internet websites, browse, and connect to other remote networks (ex. 10.5.1.0/24)
On the other hand, a remote network (ex. 10.5.1.0/24) needs to have access to internal network 192.168.1.0/24
Can you provide an example?
Just remove the previous rules typing the same command again with the keyword ''no'' in front.
Try to get Internet access from the internal networks.
I saw the diagram, just out of curiosity, why do you have public IP addresses in your internal networks?
Federico.
37 Replies 37
These are the basic Firewall rules:
The traffic flow through interfaces based on the security level.
Security level ranges from (0-100)
When communicating from a higher security interface to a lower security interface (inside to outside), you need a STATIC NAT and ACL permiting the traffic.
When communicating from a lower security interface to a higher security interface (outside to inside), you just need NAT.
In your example:
To allow
192.168.1.0/24
192.168.2.0/24
to get to the Internet, you should have:
nat (inside) 1 192.168.1.0 255.255.255.0
nat (inside) 2 192.168.2.0 255.255.255.0
global (outside) 1 interface
global (outside) 2 interface
To allow communication TO servers in the internal network 192.168.1.0/24 from the Internet, for example to 192.168.1.8
static (in,out) public_IP 192.168.1.8
access-list OUTSIDE permit ip any host public_IP
access-group OUTSIDE in interface outside
Federico.
hi federico,
I created the rules base on your instructions, but, the internal network can not access any outside websites.
The 192.168.1.0/24 and 192.168.2.0/24 do not have any servers to offer to the public. Instead, the internal networks are computers that needs to access resources outside of the firewall.
Ok,
What you're missing is the routing.
The internal networks should have a route to the Internet pointing to the ASA (or have the ASA as their default gateway).
The ASA as well should have a default gateway:
route outside 0 0 x.x.x.x
In this case x.x.x.x represents the IP of the next-hop (next device) in the path to the Internet from the ASA.
Check it out and let us know.
Federico.
ok, let me send you my temporary configuration.
PIX Version 6.3(5)
interface ethernet0 auto
interface ethernet1 auto
interface ethernet2 auto
interface ethernet3 auto shutdown
interface ethernet4 auto shutdown
interface ethernet5 auto shutdown
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 intf2 security4
nameif ethernet3 intf3 security6
nameif ethernet4 intf4 security8
nameif ethernet5 intf5 security10
enable password DAyT8Zy5o1YlaDcM encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
hostname LVCLC-FW
domain-name lv.psu.edu
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
object-group service webservices tcp
  port-object eq www
  port-object eq https
  port-object eq ftp
  port-object eq telnet
  port-object eq ssh
object-group icmp-type icmp-allowed
  icmp-object echo
  icmp-object time-exceeded
object-group protocol tcpudp
  protocol-object udp
  protocol-object tcp
  protocol-object esp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
ip address outside 172.31.53.100 255.255.255.0
ip address inside 146.186.174.129 255.255.255.192
ip address intf2 128.118.6.129 255.255.255.128
no ip address intf3
no ip address intf4
no ip address intf5
ip audit info action alarm
ip audit attack action alarm
no failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address intf2
no failover ip address intf3
no failover ip address intf4
no failover ip address intf5
pdm history enable
arp timeout 14400
route inside 0.0.0.0 0.0.0.0 172.31.53.100 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server LOCAL protocol local
http server enable
http 146.186.174.128 255.255.255.192 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
I see some problems.
The PIX has no clue as to where networks 192.168.1.0/24 and 192.168.2.0/24 are (there are no routes)
Are those networks reachable via which interface on the ASA?
The default route on the PIX is set to the inside interface. Is this the interface connected to the Internet?
Federico.
on the configuration file, the two internal networks are:
128.118.6.128 255.255.255.128
The external (public address) is 172.31.53.0/24 or 172.31.53.100/24
Both internal networks needs to go out. These are just computers that will access resources (servers, webserservers, etc.) to public network.
Take a look at the attach file.|
nat (inside) 1 146.186.174.128 255.255.255.129
nat (intf2) 1 128.118.6.128 255.255.255.128
access-list inside permit ip any any
Make sure that both internal networks have the ASA as the default gateway.
Federico.
what should I do with the other rules created? should I have them removed?
On my last submission, I uploaded a diagram for you to comment on.
Federico.
these are testing ip address, until we get the firewall correctly working..
Before uploading the new config, is this sound much better?
PIX Version 6.3(5)
hostname LVCLC-FW
names
  port-object eq www
  port-object eq ftp
  port-object eq ssh
  icmp-object echo
  protocol-object udp
  protocol-object tcp
  protocol-object esp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
no ip address intf3
no ip address intf4
no ip address intf5
no failover
failover poll 15
pdm history enable
arp timeout 14400
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Jennifer Halim
This route is incorrect: route inside  0.0.0.0 0.0.0.0 172.31.53.100 1
172.31.53.100 is your outside interface ip address. You can't route the default gateway back to your inside.
The default route should say: route outside 0.0.0.0 0.0.0.0 172.31.53.x
172.31.53.x should the next hop router ip address connected to the PIX outside interface.
and please remove the "route inside" command.
ok, thanks for the suggestion..
PIX Version 6.3(5)
hostname LVCLC-FW
names
  port-object eq www
  port-object eq ftp
  port-object eq ssh
  icmp-object echo
  protocol-object udp
  protocol-object tcp
  protocol-object esp
pager lines 24
mtu outside 1500
mtu inside 1500
mtu intf2 1500
mtu intf3 1500
mtu intf4 1500
mtu intf5 1500
no ip address intf3
no ip address intf4
no ip address intf5
no failover
failover poll 15
pdm history enable
arp timeout 14400
route outside 0.0.0.0 0.0.0.0 172.31.53.100 172.31.53.106
http server enable
floodguard enable
telnet timeout 5
ssh timeout 5
console timeout 0
terminal width 80
Have you tried it already?
Federico.
