LMS 3.2
Answered Question
Apr 7th, 2010
Hello clarke,
I have LMS 3.2 product,But i have all HP switches,will it be worth to discover HP switches in LMS,and what feature's will be available for HP switches from LMS.
Correct Answer by Joe Clarke about 6 years 11 months ago
No, software and config management cannot be done.  You can bring up Device Center, but the device will only have very generic options (e.g. ping, traceroute, SNMP Walk, etc.).
Overall Rating: 5 (1 ratings)
Joe Clarke Wed, 04/07/2010 - 23:30
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
LMS is designed to manage Cisco devices.  You will not get much value for non-Cisco equipment.  RME will be able to do some basic MIB-II inventory collection, and you can setup pollers in the Health and Utilization Monitor add-on, but that's about it.  Those HP devices will also count against your license, so it's best to not add them to the various LMS applications.
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
thomasandy32 Thu, 04/08/2010 - 00:04
Hello Clarke,
RME will be able to do some basic MIB-II inventory collection ????
what is MIB-II inventory collection??
I don't have a HUM included in that it is not extension only the base model.
Thanks for kind reply.
thomasandy32 Fri, 04/09/2010 - 14:08
Thanks clarke,
Can i  do software deployment,config deployment,use of device centre,vlan configurtion ??????    OR just what u have mentioned above.
Thanks once again for ur prompt reply
Correct Answer
Joe Clarke Sun, 04/11/2010 - 17:34
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
