CallManager 7.0(1), How to make a middle point of call initiation
Apr 7th, 2010
Hi all,
I have a customer who has the following issue:
- The phone-assistant dial an extern number (through PSTN)
- After call is connected, she/he transfers this call to a further external call (as well through PSTN)
- When the second PSTN-call is build up, she/he uses the transfer soft-key a second time (to transfer those PSTN calls togheter),
  and then, both calls are disconnected.
An incoming call (form PSTN or internal) can be transfered internal/PSTN without issuse. It's only the function "middle point of call initiation" that
is mistaken.
Who can put on the right direction?
The setup:
- CallManager 7.0(1)
- 2821 PSTN-GW (H323)
Thanks an greets,
alig.norbert Sat, 04/10/2010 - 02:53
I figured it out.
Had to activate "Media Termination Point Required" on H323-Gateway settings (CUCM).
