Catalyst 2960-S Uplink ports
Answered Question
Apr 7th, 2010
I need to know if the new catalyst 2960-S support on the same model both uplink type for 1gig & 10gig?
how can we migrate from 1gig to 10gig with this same switch?
regards.
Adil
Correct Answer by Collin Clark about 6 years 11 months ago
If you want to use 10GB, then you must use the SFP+ and for 1GB you can use SFP. The switch will support either one. Does that answer your question?
Overall Rating: 5 (1 ratings)
Sindibade 78 Wed, 04/07/2010 - 14:10
Hi collin
thk you for your response, i have previously seen this datasheet but it's not clear about support of both type of tranceiver for 10gig & 1gig.
for ht same model like Cisco Catalyst 2960S-48FPD-L. can we use both type of tranceivers?
regards
Correct Answer
Collin Clark Wed, 04/07/2010 - 14:20
  • Purple, 4500 points or more
Sindibade 78 Wed, 04/07/2010 - 14:24
is the SFP+ support both speed 1gig & 10gig or we must change the transceiver to SFP if we need just 1gig?
Collin Clark Wed, 04/07/2010 - 14:25
I believe the 10GB SFP+ is 10GB only. I'll see if I can find a supporting document.
Leo Laohoo Wed, 04/07/2010 - 16:22
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Collin is right.  The SFP+ will only support 10Gb and does not auto-negotiate to any other speed.
