3750X-48T Blocking
Apr 7th, 2010
Hi, the data sheet for the device in the subject does not show the blocking ratio for port forwarding, ie 20:1.
It does provide the switching fabric 160Gb and forwarding rate 101.2 mpps.
My question is, what is the blocking ratio for this switch and if it's not on the datasheet, how can it be determined?
Jon Marshall Wed, 04/07/2010 - 14:51
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Robert
Not exactly sure what you mean. The 3750X switches are like the 3750-E switches ie. they are non-blocking.
Jon
