Jon Marshall Wed, 04/07/2010 - 15:02
adil-taleb wrote:
Are ther is supervisor for CAT 4500 that support 650 Gbps switching capacity with min 400Mpps without passing to CAT 6500.
best regards
Adil
No basically, the 4500 does not have a supervisor that will provide that switching capacity. So you would need to look at either the 6500 or Nexus switches for that type of throughput.
Jon
Cisco are currently donating money to the Haiti earthquake appeal for every rating so please consider rating all helpful posts.
Ganesh Hariharan Wed, 04/07/2010 - 23:23
best regards
As suggested by Jon 4500 series with sup 6-E can only support til 320 Gbps and 250 Mpps of throughput for higher range need to move to 6500 series,check out the below link for more information
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps9294/product_data_sheet0900aecd806df543_ps4324_Products_Data_Sheet.html
Hope to help !!
Ganesh.H
Remember to rate the helpful post
