ACS4.2 service impact in enabling NDGs?
Apr 7th, 2010
hello,    we have an operational ACS4.2 with NDG not enabled.   Just trying to find out the service impact of enabling NDGs on the existing AAA clients?
Will the existing clients be left in the top level with no NDG?
The MAR feature is also operational, will the MAR cache be impacted at all?
Thanks in advance
Jagdeep Gambhir Thu, 04/08/2010 - 09:23
  • Red, 2250 points or more
Hi Graeme,
When you enable NDG feature all existing client will become  a member of Not Assigned group, then you can manually assign client to  specific NDG.
Caution: You can also set up shared  secret key on NDG level. If you set up secret key for NDG that will  be used instead of key configured on the aaa-client
~JG
Do  rate helpful posts.
Related Content
