AXL Query Device IP
Answered Question
Apr 7th, 2010
Hi, can't seem be find any AXL query that can return device IP address, possible via AXL ?
Correct Answer by William Bell about 7 years 1 month ago
Actually, the AXL interface is only used for viewing and/or modifying configurations. The API you are looking for is the Serviceability XML API. Specifically, RISPort. It is pretty handy and a solid replacement for devicelistx.asp (if you are familiar with that "API"). I have worked with RISport a little and put together some blogs on the subject. If you are interested, check them out:
http://www.netcraftsmen.net/resources/blogs/good-bye-devicelistx-asp-hel...
http://www.netcraftsmen.net/resources/blogs/identifying-the-correct-devi...
Another good place to look for information on the API: http://developer.cisco.com/web/sxml/home
What you need to look at is the Real-Time Device/CTI feed (RISport).
HTH.
Bill
Please remember to rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
William Bell Wed, 04/07/2010 - 21:29
  • Purple, 4500 points or more
HTH.
Bill
Gerald Chong Wed, 04/07/2010 - 23:59
Thanks for the reply.
Just tested with RISPort request, and CM7 keep returning HTTP Status 500 internal error.
Have you come across this error before?
Gerald Chong Thu, 04/08/2010 - 19:30
All sorted, WSDL had changed, corrected the XML all working correctly.
William Bell Fri, 04/09/2010 - 05:56
Good to hear. Sorry I missed your earlier query about the http status error but it appears you got it all worked out.
Bill
Related Content
