CUCM 6.1.4 Security Password Lost
Answered Question
Apr 7th, 2010
     Hello All,
Do you know a way to recover/reset the CUCM Security Password without knowinng the actual one? I have lost it.
Correct Answer by Aaron Harrison about 7 years 2 weeks ago
From the server CLI, log in as:
pwrecovery
pwreset
It will ask you to insert/pop a CD into the server (this can be any CD/DVD, just to prove you have physical access to the server and therefore are OK to reset it).
You should then get a prompt to choose either the admin password (CLI admin user) or the security password (cluster password).
Bear in mind if you change the admin user, you can do this and have different passwords on each server.
If you change the cluster password, you need to set it the same on all servers, and restart all the servers, or your cluster will be unhappy.
Aaron
Please rate helpful posts..
Overall Rating: 5 (3 ratings)
Correct Answer
Aaron Harrison Thu, 04/08/2010 - 01:07
  • Community Spotlight Award,
    Member's Choice, May 2015
pwrecovery
pwreset
Aaron
mcecilia Thu, 04/08/2010 - 01:35
Thanks for the answer, it seems to be clear but does not work.
When I try to login using ssh to the server, with pwrecovery/pwreset it does not allows me.
Any idea?
Aaron Harrison Thu, 04/08/2010 - 01:39
The whole point of the CD-in/CD-out routine is to prove you have physical access to the server.
The other part of that is you need to be at the console, not via SSH.
You could get away with access via iLO if you have that configured already, I imagine...
Aaron
Please rate helpful posts...
mcecilia Thu, 04/08/2010 - 03:57
The problem was I was not seat in front of the server.
Now worked.
