EIGRP routing
Answered Question
Apr 8th, 2010
I have ASA 5510 with 8.2(1) software. My EIGRP configuration is:
route outside 0.0.0.0 0.0.0.0 x.x.x.x
router eigrp 1
no auto-summary
no default-information in
no default-information out
default-metric 100000 10 255 1 1500
eigrp stub connected static
network 10.x.x.x 255.255.255.248
network 10.x.x.x 255.255.255.240
network 10.x.x.x 255.255.255.0
redistribute static metric 100000 10 255 1 1500
I can not prevent ASA to advertise default route, is there a mistake with my configuration?
Correct Answer by Jennifer Halim about 6 years 11 months ago
You redistribute static into eigrp.
You can create a route-map to surpress the static default route to be redistributed to eigrp.
Overall Rating: 5 (1 ratings)
Correct Answer
Jennifer Halim Thu, 04/08/2010 - 01:54
  • Cisco Employee,
NemanjaPoprzen Thu, 04/08/2010 - 02:56
You are right, route-map solved problem with default route. "no default-information out" command confused me.
Thank you.
