SCTP and Pix 515 ? Supported ?
Apr 8th, 2010
)Folks,
I did a search, only came up with a few unfinished threads. We have an older Pix, which seems to be still holding it's own, until now.
Have a VPN between 2 sites. (Pix to Pix). No NAT involved in the VPN ( /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} nat (inside) 0 access-list toFortWorth).
All other things work fine, ping, telnet, ftp, etc. They are trying to do SCTP back & Forth, Firewalls dont even see the traffic at all.
Tunnel wont come up, nothing in the capture...
Ive read that Cisco doesnt support SCTP in older technologies.
Can anyone verify for me, if SCTP can work on the Pix? is it supported?
Thanks!
Cisco PIX Firewall Version 6.3(5)
Compiled on Thu 04-Aug-05 21:40 by morlee
MA35-MotISP-FW up 317 days 6 hours
Hardware:   PIX-515, 64 MB RAM, CPU Pentium 200 MHz
~Dave
