CUCM 7 Admin Page Timeout
Answered Question
Apr 8th, 2010
Quick one.......
Can someone tell me where you can (or if you can) change the time that the CUCM Admin page takes to timeout from inactivity & make you re-login again?
Cheers
Russell
Correct Answer by Jonathan Schulenberg about 7 years 3 weeks ago
This has been answered on the forums many times already. Please use the search function before opening new threads!
This cannot be modified in any currently available version.
Overall Rating: 3.3 (5 ratings)
Correct Answer
Jonathan Schulenberg Thu, 04/08/2010 - 02:45
  • Cisco Designated VIP,
    2017 IP Telephony
Rob Huffman Thu, 04/08/2010 - 05:21
  • Hall of Fame,
    Founding Member
    2017 IP Telephony, Unified Communications
Hi Russell,
Just to add a note to the good info from Jonathan (+5"J")
This was posted up by Java a short while back, it's probably one
worth keeping an eye on
CSCsj45520
CM 6.0/7.0 Customer should be able to configure/disable CCMAdmin timeout
Symptom:
Browser session to CCMAdmin times out after 30 minutes and user must re-authenticate.
Conditions:
Browser session to CCMAdmin idle for 30 minutes with CM6.x.
Workaround:
None.  Reauthenticate after 30 minutes of inactivity.
Further Problem Description:
This is an enhancement request to allow configuration of web session timeout.  Please contact Cisco account team or Cisco Product Manager for status, details, and updates about this enhancement request.
Cheers!
Rob
Please support CSC Helps Haiti
https://supportforums.cisco.com/docs/DOC-8895
https://supportforums.cisco.com/docs/DOC-8727
