Pinging to broadcast address
Apr 8th, 2010
Although there is no host present with broadcast address (192.168.1.255) ping responce is received how can we stop this?
Tried using ip directed broadcast but some how it's still responding to broadcast address.
Please share the experience to stop broadcast replies.
Subodh
Giuseppe Larosa Thu, 04/08/2010 - 05:00
  • Hall of Fame,
    Founding Member
Hello Subodh,
if you want that ping to directed broadcast 192.168.1.255 is not sent out on a router interface you need to use
int type x/y
no ip directed-broadcast
you can check this setting using
sh ip interface typex/y
example:
sh ip int vlan160 | inc irected
  Directed broadcast forwarding is disable
sh run int vlan 160 | inc ip address
ip address 10.54.120.4 255.255.255.0
ping 10.54.120.255
Sending 5, 100-byte ICMP Echos to 10.54.120.255, timeout is 2 seconds:
Reply to request 0 from 10.54.120.5, 4 ms
Reply to request 1 from 10.54.120.5, 1 ms
Reply to request 2 from 10.54.120.5, 1 ms
Reply to request 3 from 10.54.120.5, 1 ms
Reply to request 4 from 10.54.120.5, 1 ms
the answer comes from the companion switch (a pair of C6500 at distribution layer in a campus network)
however, this setting does not stop packets originated at router itself  as shown above
Hope to help
Giuseppe
Rate useful posts to help Haiti
