04-08-2010 05:55 AM - edited 07-03-2021 06:42 PM
We have just acquired a set new LAP1142N but they cannot successfully register with existing 4402 WLCrunning .
Other existing APs include 1130AG and 1240AG.
Any idea what could cause thsuch problem
Solved! Go to Solution.
04-08-2010 06:22 AM
What version are you running on the controller? The 1140 AP's are not supported until 5.2 and higher code.
04-08-2010 06:22 AM
04-08-2010 10:02 AM
Many thanks for this info. My controller runs version 4.1 as can be seen on the output below.
(NGPHCIAWC002) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 4.1.171.0
RTOS Version..................................... 4.1.171.0
Bootloader Version............................... 4.1.171.0
Will try and Upgrade ASAP.
04-08-2010 03:35 PM
Stay away from 5.X. Go to the 6.X instead.
